2000 Honda Accord Turn signal problem
BOMBERBILL
Electrical problem
2000 Honda Accord 4 cyl Front Wheel Drive Automatic
When engaging the turn signal switch, the speed of the flashing is higher for a right turn and normal speed for the left turn. Checked the lights to see if one was burned out, however the right side blinker lights all light up but at a lower brightness than the left side--suspect a flasher relay is the culprit but do not know where it's located and how to identify it
Jul 30, 2008 at 2:19 PM
KHLOW2008
  • 41,812 POSTS
Hi bomberbill,
Relay is located in Driver side fuse box, lower RH corner.
Turn Hazard switch on and you can feel the clicking on the relay.
Aug 1, 2008 at 10:45 PM
