Electrical problem
2000 Honda Accord 4 cyl Front Wheel Drive Automatic
When engaging the turn signal switch, the speed of the flashing is higher for a right turn and normal speed for the left turn. Checked the lights to see if one was burned out, however the right side blinker lights all light up but at a lower brightness than the left side--suspect a flasher relay is the culprit but do not know where it's located and how to identify it
Jul 30, 2008 at 2:19 PM
