2000 Honda Accord Transmission change trouble
106,000 MILES • 4 CYL • 2WD • AUTOMATIC
SATYANARAIN.SHARMA1
I have 2000 honda accord. Problem is when I am running the car and i have to stop the car (for example) at STOP sign and hit the Gas, car takes 3-5 second to pickup. It is as if i have turned the gear to "N". Also, when i stop the car, at the end of the stop it give a small jerk. Do i need to go for the transmission service or Fluid level is low?
Aug 14, 2008 at 7:59 AM
KHLOW2008
  • 41,812 POSTS
Since you suspect the ATF might be low, why don't you give it a check first? The owners manual has a full description on how to do it.
Aug 15, 2008 at 2:37 AM
