2000 Honda Accord Power Steering Pump
168,000 MILES • 6 CYL • FWD • AUTOMATIC
ALPOLLARD73
I have a 2000 Honda Accord V6 and I replaced the Power Steering Pump twice and I still have a problem . This time theres a screeching noise when I turn the wheels either way and the fluid is foaming up out of the reserve tank. Any suggestions to this problem. Could it be the hose/ filter being clogged, or just another bad pump like the first one. PLEASE HELP!!!
May 25, 2008 at 12:13 AM
KHLOW2008
  • 41,812 POSTS
Hi there,
Yuor problem is one of air being sucked by the pump when operating.
Check for leakage along hose from reserve tank to pump. Did you change the O ring at the pump joint of the supply hose?
If no leakage is found, then you got a problem with the pump again.
May 25, 2008 at 12:22 AM
