2000 Honda Accord PASSENGER SIDE MIRROR
138,000 MILES • 6 CYL • 2WD • AUTOMATIC
NUCCHAP
My passenger side mirror has been broken off except for the electrical cable from which it is hanging. How do I disconnect this cable? I have already unscrewed the assembly by removing the interior panel. It seems as though it should simply "unplug" but I haven't applied sufficient force (yet) to make this happen. Help.
Nov 12, 2009 at 12:17 PM
HONDA TECH 1818
  • 536 POSTS
The mirror assembly has 3 8mm bolts that holds it and you need to remove the passenger door panel to disconnect the wire harness. Try to use a flat head screwdriver to pry the broken part off.
Nov 12, 2009 at 6:01 PM
