2000 Honda Accord Oil Pump
10,800 MILES • 4 CYL • FWD • AUTOMATIC
ROMEDAWG101
Hey I am trying to replace my oil pump and i took off the front left tire to get to it and then there is the disc that holds a belt. I cant seem to take that disc off . . what do you suggest?
Sep 9, 2010 at 9:52 AM
F4I_GUY
  • 3,302 POSTS
If you cannot remove the crankshaft pulley (the disc) I do not recommend that you attempt to remove the oil pump. It is a very complicated job that most general mechanics do not even attempt.
Why do you think you need an oil pump anyways? I've never seen one fail on your vehicle.
Sep 9, 2010 at 11:21 AM
ROMEDAWG101
oh no, no its not the crankshaft pulley. Thats on top by my engine. The disk is on the bottom. I need to remove that disc that the belt is held on by the left tire disc so i can get to the oil pump. My oil is leaking thats the problem. I notice my repair light turned on and i checked my oil and it was empty.
so i poored oil in and noticed a big puddle at the bottom of my car. That means, everything i just poored in, came out. ill send you a picture as soon as i can.
Sep 10, 2010 at 1:16 AM
ROMEDAWG101
sorry it is the crankshaft pulley.
i tried heating i just cant get it off!
Sep 10, 2010 at 4:13 PM
