2000 Honda Accord missfire
BOBNBRENDAJ
  • 2000 HONDA ACCORD
  • 6 CYL
  • FWD
  • 135,000 MILES
My 2000 accord starts and idles fine when cold but when hot, it idles rough and sends a check engine code 7. When it cools down, it starts and idles fine. I have also noticed a very rough shifting of atf at cold temp, after a mile or two it shifts fine. Could it be the Throttle position sensor?
Saturday, October 16th, 2010 AT 6:23 PM
KHLOW2008
  • 41,814 POSTS
Hi Bobnbrendaj,
If the MIL is indicating and retrieved code is 7, then it definitely is a fault with the TPS.
Was it adjusted or tampered with prior to this occurring?
Hav you tried adjusting the TPS?
Saturday, October 16th, 2010 AT 11:41 PM
BOBNBRENDAJ
No, I have not tried adjusting it. Where is it located? On a Honda 2000 Accord is it adjustable? If I could find it I could check wires leading into it etc, but I can't find it.
Thanks So much, Bob
Sunday, October 17th, 2010 AT 5:49 AM
KHLOW2008
  • 41,814 POSTS
TPS is located on throttle body and if it is faulty, throttle body has to be replaced as assembly.
Adjustment is possible but TPS is held by torx bolts.
Sunday, October 17th, 2010 AT 8:49 AM
