2000 Honda Accord locked front brakes
64,000 MILES • 6 CYL • FWD • AUTOMATIC
NORTHCENTRALMA
My wife came home and the front brakes on the car where almost on fire yesterday. I changed both front calipers, rotors and all the rubber hoses front and back. Now I can't seem to bleed the brakes. I think it is something with the ABS but don't know for sure. How can I check this? The ABS light comes on at the start of the car but then goes out so I think that means the system checks "OK".
Dec 17, 2009 at 10:26 AM
MSESKY
  • 14 POSTS
Are you bleeding them manually? if so you should only do half pushes on the brake pedal, instead of pushing the pedal all the way to your floor as i know this can damage the diaphram or some seal in the master cylinder, which means it wont be pushing the fluid through. It also takes a while for the fluid to get through when you replace the callipers
Dec 20, 2009 at 6:32 PM
