[quote:c9a9f1e9c0="jbivens"]Engine Mechanical problem
2000 Honda Accord 4 cyl Front Wheel Drive Automatic 140000 miles
my engine light is on code 1486 thermostat where is the thermostat[/quote:c9a9f1e9c0]
This is the defs I have for your code...
Honda Specific Code
P1486 Thermostat Range/Performance Problem - You should be able to just follow the upper hose from the radiator to the engiine and the thermostat is right there.
OBD2 Code
P1486 Evap Leak Monitor Pinched Hose.
Which indicated that there is a colapsed vacuum line somewhere.
Feb 27, 2009 at 6:05 AM
