2000 Honda Accord HELP! After spending $800. Car still has
2000 HONDA ACCORD
PHILLYPHI
Engine Performance problem
2000 Honda Accord 4 cyl Two Wheel Drive Automatic
Blew my head gasket. So I got a top half kit and changed the top half of my engine. Car starts right up fine. When in idle it fluctuates a little. When I step on the pedal to rev the engine and let go the car dies. While accelerating car idle drops down and loses power. Then it regains power and then drops back down. Going uphill or down. Got it diagnosed with HONDA and they stated I needed a new IACV (idle air control valve) and a IAT Sensor (intake air temperature sensor). I changed that also and car still has the same problems. I NEED HEP PLEASE !!!!!!!! Can anyone out there help me?
May 28, 2010 at 3:57 AM
  • 31,937 POSTS
Hi there,
have you check that all the vacuum lines are correct and that there is no vacuum leak at the manifold.
mark (Mhpautos)
May 28, 2010 at 4:16 AM
PHILLYPHI
Wondering if that was the only solution.
May 28, 2010 at 4:24 AM
  • 31,937 POSTS
This is a common problem and often it is vacuum related, so best check this first, if that is all OK, we move on,
Mark
May 28, 2010 at 6:18 AM
