Frequently the battery, doors open, and abs lights will flicker in the dash. The alternator has been changed twice in the past 5 months. I still have the 1st replacement alternator and had it and the currently installed alternator checked, along with the battery. All tested fine. Each time I have it looked at the mechanics say I should replace the alternator. However, none of the other dash lights, interior lights, or head lights are affected. The door locks would activate on their own along with the flickering dash lights prior to replacing the alternator the 1st time but that no longer happens. Also, it doesn't matter if the engine is idling at for the 3 dash lights to flicker. What would be the cause of this problem?
Sep 15, 2008 at 4:33 AM
