2000 Honda Accord Engine won't turnover
JOLLYHOMBRE
  • 2000 HONDA ACCORD
  • 4 CYL
  • FWD
  • MANUAL
  • 222,000 MILES
I got in my car yesterday, accidentally hit my remote car lock. I did not unlock the car before attempting to start it. The engine did not turn over. Could this have immobilized the fuel? I have disconnected the battery and tried to restart.
The battery is relatively new.
Car is well over due for a tune up.
Could it be as simple as replacing spark plugs and fuel filter?
Sunday, December 6th, 2009 AT 11:31 AM
KHLOW2008
  • 41,814 POSTS
Hi jollyhombre,
When the alarm is activated, it would prevent the vehicle from being started.
Use the remote to arm and disarm and test if you could start.
Are you able to crank the engine?
Monday, December 7th, 2009 AT 7:37 AM
JOLLYHOMBRE
I have armed and disarmed the alarm.
The engine tries to start (cranks?) But does not quite make it.
I contacted honda, and they said it should have nothing to do with the alarm. I thought it might have been, since I have not had issues with it starting.
It sounds like I will need to have a mechanic look at it.
Monday, December 7th, 2009 AT 8:56 AM
KHLOW2008
  • 41,814 POSTS
If you are able to crank without it starting, it could be fuel or ignition that is malfunctioning.
If the cranking speed is slow, you might have a weak battery, a jump start would solve the problem.
If you are into DIY, try this link to see if you can get any idea what could be missing. Otherwise you would have to get someone to look at it.
http://www.2carpros.com/first_things/car_cranks_but_wont_start.htm
If you require additional assistance, let me know.
Tuesday, December 8th, 2009 AT 6:13 AM
