2000 Honda Accord engine knock
2000 HONDA ACCORD
160,000 MILES • 6 CYL • FWD • AUTOMATIC
HAYTHE5
my accord went into a ditch. my engine was in water. i have an exposed intake. i am concerned that it sucked in water. when i start it up i here a knocking sound. is this water in the crank case? if i drain the oil out and let it dry wiil this help?
Oct 2, 2010 at 8:43 AM
KHLOW2008
  • 41,814 POSTS
Hi haythe5,
Symptoms indicates water has entered the cylinders and bent a con-rod slightly. A compression test would confirm this.
Replacing th oil is not going to help.
Oct 3, 2010 at 5:30 AM
