2000 Honda Accord Electrical
84,000 MILES • 6 CYL • FWD • AUTOMATIC
RNDGM
Car was difficult to start and ran rough couple of days. Even jerked into gear while driving. Would not start so replaced old battery then car ran fine for 2 days only drove 50 miles before problem started again. Dash light was dim and then car felt like is was not able to get power when gas peddle pressed down. dash lights abs and srs then all lights on dash came on then all gauges went down and engine died. Tried to start again acted as if battery was dead, waited and then it did start up but did not run for long maybe 3-5min then died. Could this be wiring, electric, computer?? Any recalls? Thank you.
Jan 13, 2008 at 1:42 PM
JEREMIAH
  • 217 POSTS
sounds like a problem with power supply.check the condition of your battery again,if the new one is already dead then that means that the alternator is not charging the battery.
Jan 13, 2008 at 2:00 PM
