2000 Honda Accord egr valve
DAVICHEEMA
Engine Mechanical problem
2000 Honda Accord 4 cyl Front Wheel Drive 147000 miles
my uk honda accord eml has come on again,the last time i checked this on a reader was the egr valve stuck,this is my second egr valve and the same code has come on again,the carbon is thicker coated on the bottom of the valve this time. .i was told to remove the manifolfd to remove carbon? is this the inlet manifold?? i was also told it might be the engine oil im using.i use 10-40 engine oil.otherwise i hav had no probs with this car in the 6yrs i have owned it.
Jan 20, 2009 at 7:00 PM
ZACKMAN
  • 4,202 POSTS
That will be your intake/inlet manifold. I don't know about UK recommendation, but here in the US all Honda vehicles are to use 5-20. You may want to check your manual, or at least call up your local Honda dealer.
Jan 21, 2009 at 4:29 PM
DAVICHEEMA
HELLO I HAVE THE CODE P0149 ON MY UK REGISTERED HONDA ACCORD2.0, YEAR 2000,PLS COULD YOU TELL ME HOW TO FIX THIS PROBLEM. COULD THIS BE AN ELECTRICAL RELAY OR A MECHANICAL FAULT, WHERE COULD I FIND THIS ON MY VEHICLE....PLS HELP
Jan 21, 2009 at 5:32 PM
ZACKMAN
  • 4,202 POSTS
P0149....Fuel Timing Error. Usually related to vehicle jumped timed, or distributor out of time.
Jan 21, 2009 at 8:17 PM
DAVICHEEMA
sorry i gave you the wrong code.the code was P0419 ON THE HONDA ACCORD. how can i fix this???????????
Jan 21, 2009 at 9:26 PM
ZACKMAN
  • 4,202 POSTS
P0419 Secondary Air Injection System Relay "B" Circuit Malfunction. I have to do more research on this. In the mean time, you need to make sure that all the sensors are within range.
https://images.2carpros.com/forum/automotive_pictures/55316_00accorddiag1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/55316_00accorddiag2_1.jpg
Jan 22, 2009 at 11:12 AM
