2000 Honda Accord DRIVER SIDE POWER WINDOW CABLE
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
KROWBERRY
HOW TO REPAIR BROKEN CABLE ON THE DRIVER FRONT SIDE
Jun 17, 2010 at 4:18 AM
KHLOW2008
  • 41,812 POSTS
Hi krowberry,
Thank you for the donation.
The component is non serviceable and you would need to replace the regulator assy which comes as a set.
Jun 18, 2010 at 8:36 AM
KROWBERRY
Do you have instruction for replacing the regulator?
Jun 18, 2010 at 9:12 AM
KHLOW2008
  • 41,812 POSTS
Our database does not have the procedures for replacement of the windor regulator but I have emailed some files to you which would help in removing the trims.
After removal of the trims and disconnecting the window motor wires, disconnect the door glass from the regiulator.
Look at your replacement regulator and note the mounting bolts for the door glass, regulator and window motor.
No adjustment are required so it is just a straight forward job and before final installation of the panels, remember to test if the window works smoothly.
Jun 18, 2010 at 11:27 PM
