2000 Honda Accord distributer cap
2000 HONDA ACCORD
200,000 MILES • 4 CYL • FWD • AUTOMATIC
BOUNCERX
hey i changed a heater hose on the car.all i did was take the distributer cap off and replaced the hose.now the car wont crank ive looked and everything is connected.got any ideas?
May 16, 2009 at 12:12 PM
BOUNCERX
i need AN answer fast
May 16, 2009 at 12:13 PM
F4I_GUY
  • 3,302 POSTS
Check for battery voltage at the larger power wire on the starter. Then while a helper cranks the vehicle (or attempts to) check for voltage at the smaller wire that goes to the starter motor. If that is in check, ensure all your ground cables (esp. the one on the transmission) are not corroded and they are good and tight. If that checks out, replace the starter.
May 17, 2009 at 11:28 AM
