2000 Honda Accord DASHBOARD TEMP DISPLAY
BDPITTS
Electrical problem
2000 Honda Accord 6 cyl Two Wheel Drive Automatic
TEMP DISPLAY LIGHT HAS GONE OUT. HOW DO YOU TELL WHICH BULB HAS BLOWN AND ARE THEY READILY AVAILABLE? THANKS!
Dec 4, 2008 at 3:28 AM
KHLOW2008
  • 41,812 POSTS
Hi BDPITTS,
You need to test the bulb to see which have blown. visual inspection is possible only if you know which are the bulbs and you need to partially remove the panel to visually inspect.
Bulbs are dealers parts and not that easily available.
Dec 5, 2008 at 1:06 AM
