Hi, Terrence41 u may want to check your fuses make sure u didn't blow a fuse and if that doesn't work make sure u connected everthing back together, also if you are wanting to get it out of park if you look around your shifter you should find a cap or a cover with a slit pop that off and stick a pen or something small in it and u should be able to get it out of park. Hope this helps :)
Nov 5, 2010 at 9:00 PM
