2000 Honda Accord Change light on dash and shifter wont get
135,000 MILES • 4 CYL • FWD • AUTOMATIC
TERRENCE41
i attempted to install a missing srs light and car wont get out of park now and power windows wont work
Nov 5, 2010 at 3:32 PM
FUNGUY4
  • 39 POSTS
Hi, Terrence41 u may want to check your fuses make sure u didn't blow a fuse and if that doesn't work make sure u connected everthing back together, also if you are wanting to get it out of park if you look around your shifter you should find a cap or a cover with a slit pop that off and stick a pen or something small in it and u should be able to get it out of park. Hope this helps :)
Nov 5, 2010 at 9:00 PM
KHLOW2008
  • 41,812 POSTS
Yes, check the fuses and ensure the brake lights are working correctly.
Nov 6, 2010 at 12:51 AM
