The ABS light is on, and its throwing the following code. One long flash, followed by 3 short flashes
142,000 MILES • 6 CYL • FWD • AUTOMATIC
SPDRACE025
Hello. I have a 2000 Honda Accord- 6cyl, The ABS light is on, and its throwing the following code. One long flash, followed by 3 short flashes. Any idea as to what could be wrong?
Thanks in advance!
Jun 6, 2010 at 2:09 AM
2CARPRO JACK
  • 11,533 POSTS
Code 13 is for driver side front wheel sensor open or shorted. Look for any damage to the sensor or the wiring.If ok it may need a new wheel speed sensor.Was any work done before this light came on or did it just pop on out of the blue?
Apr 23, 2021 at 6:18 AM
SPDRACE025
Hello!
It just appeared out of the blue yesterday afternoon. I checked my brake fluid, and it was a little low, (and I mean a "hair" low).. I did put a little fluid in.. but it didn't make a difference.
2CARPRO JACK
  • 11,533 POSTS
The ABS light is tied into the actual ABS system, if the fluid is low the"brake" light will come on.L/F wheel sensor issue
