2000 Honda Accord Battery Dies
BESTEBAN
I have a 2000 Accord EX and the battery keeps dieing. I was curious if anyone knew of some common problems or things I could look for. I have not had any problems with this vehicle otherwise and it seems to have just started on its own.
Nov 15, 2006 at 1:04 PM
BRUCE HUNT
  • 3,754 POSTS
Original battery? Could be the age of the battery giving up. Cables could be loose and corroded thus not allowing a good charge to the battery. After that the charging system could be the problem.
Nov 15, 2006 at 1:28 PM
Suggested Repair
Check whether the battery is original or aged and replace it if weak. Inspect battery cables and terminals for looseness and corrosion so the battery can charge properly, then test the charging system.
Conversation Summary
The owner of a 2000 Honda Accord EX says the battery keeps dying even though the car has otherwise had no problems. The expert suggests the battery may simply be old, that loose or corroded cables may prevent a good charge, and that the charging system should be checked next.
