1999 Honda Accord window regulator
JUCO
1999 Honda Accord 4 cyl Two Wheel Drive Automatic
How do I replace the window regulator? Is it hard to do?
Jun 28, 2010 at 4:50 AM
KHLOW2008
  • 41,812 POSTS
Hi juco,
It is not really difficult to replace the window regulator if you are a DIY guy.
The door panels have to be removed and from there you can gain access to the regulator.
Disengage and remove the door glass from the regulator first.
After that remove any holding bols for the regulator and it can be removed after the wire harnesses are disconnected.
Jun 28, 2010 at 7:20 AM
