1999 Honda Accord 4 cyl Front Wheel Drive 144,00 miles
had routine timing belt replacement at about 98,00 and simultaneously replaced water pump as cost measure(no problem). Now have water pump leak and wonder if this is normal after this mileage. Also wonder if should have timing belt replaced for cost containment. Probably will keep car a while more as have no other known problem. am original owner.
Mar 14, 2010 at 9:11 AM
