1999 Honda Accord turns off???
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOSE I
Car turns on no problem, put in gear as soon as i accelerate car turns off? gas idle dropps all the way down even if gas tank is full.
any suggestions or advise??
Jul 29, 2009 at 12:58 PM
F4I_GUY
  • 3,302 POSTS
Check for proper fuel pressure at the rail. Also check for STRONG spark.
Note: You will have spark, when you test your ignition, however you need to make sure it is bright and white/blue. If it is a dull orange you got an ignition issue.
Jul 29, 2009 at 2:10 PM
