Seeking to identify trouble code 1399 and advice regarding which component(s) to replace
Jun 2, 2008 at 7:38 AM
KHLOW2008
✓Experienced Mechanic
Hi edabcd,
Wait to start lamp circuit.
Something new to me but I got a feeling something to do with the main relay.
Can the vehicle start when the code appears?
Any symptoms?
I would check it out at my office and get back to you.
Jun 3, 2008 at 2:41 AM
EDABCD
MEMBER
Yes, car starts ok while code is present. However, can feel "a miss" in motor while running a highway speeds and gas milage very noticably affected. Have received suggestions to try the coil - make sense to you.
Thanks.
Jun 3, 2008 at 10:55 PM
KHLOW2008
Hi edabcd,
It is possible for the coil to miss, but it should not be giving you any code.
Since it can start, dose the code show each time you start or intermittently.
Could not get any info for this code. Did you run any diagnostic data reading on the vehicle?
Jun 4, 2008 at 2:15 AM
EDABCD
MEMBER
The code shows each time car is started. No, did not run any diagnostic data reading on the vehicle.
Thanks for your help.
Ed
Jun 4, 2008 at 2:22 AM
KHLOW2008
Hi edabcd,
Someone with a Civic has the same problem as yours and it crossed my mind that the ECM might be possibly giving the problem. The Civic had one more code of misfiring.
