1999 Honda Accord Transmission Problems
1999 HONDA ACCORD
BIGBENGUY
Transmission problem
1999 Honda Accord 6 cyl Front Wheel Drive Automatic
After I first start my car the transmission feels like it shifts into neutral before shifting into the next gear. If you are driving slow there is a very hard jerk when it finally shifts into gear but if you are driving kind of fast you can barely feel a jerk. This only seems to happen for about 10-15 minutes after you start the car but then after that it shifts fairly smoothly. I have been keeping a close eye on the transmission fluid level and its still in good shape. What else might be a problem?
Mar 17, 2010 at 12:49 AM
KHLOW2008
  • 41,814 POSTS
Hi BigBenGuy,
Symptoms indicates a possible fault with the shift solenoids. Get a free scan done at Autozone to see if any trouble codes are stored in the PCM.
Mar 17, 2010 at 8:56 AM
