1999 Honda Accord Transmission Leaking
17,800 MILES • 4 CYL • 2WD • AUTOMATIC
CEURVELD
My transmission is leaking (small drips) and I would like to know if there is a way I can refill the transmission fluid or do I need to take it into an auto repair shop.
I can do minor repairs myself but I don't have the skills to drop the transmission.
Thank you
Apr 15, 2010 at 9:56 AM
KHLOW2008
  • 41,812 POSTS
Hi ceurveld,
Refilling the transmissio is via the dipstick. You would need a funnel with a hose.
Where is the leak coming from? If it is from the CV shaft seals, then you need not drop the transmission. Removing the /CV shaft would allow you to replace the seal.
Apr 18, 2010 at 7:44 AM
CEURVELD
Thank you very much for your quick response. I noticed the leak coming from the CV shaft the other day. I'm so glad that dropping the transmission will not be required. You have been a great help and your advice is much appreciated!
Thank you again
Sincerely
Dave C
Apr 18, 2010 at 4:26 PM
KHLOW2008
  • 41,812 POSTS
You're welcomed and if you required further assistance, just post a reply to this thread and I will get back to you once notification is received.
Apr 18, 2010 at 10:34 PM
