1999 Honda Accord Transmission and Brake fluid Flush
AJG01
Transmission problem
1999 Honda Accord 4 cyl Front Wheel Drive Automatic 118k miles
I have a '99 Accord with 118K which runs perfectly. When I had the oil change they mentioned that I should have the transmission fluid and the brake fluid flushed. Is this necessary if I am not having any problems with the car? What is a reasonable price? They are asking $200 for the transmission fluid flush and 100 for the brake fluid flush.
Mar 6, 2009 at 4:44 PM
ZACKMAN
  • 4,202 POSTS
You should perform the transmission and brake bleeding services at 90K miles. It should only be 1 hour labor plus fluid. Brake bleeding will take another .6 hours. What they quoted you too much. I would call other local shops to ask what their hourly rate is, and ask how much to perform the services you wanted.
Mar 6, 2009 at 6:36 PM
