Engine Mechanical problem
1999 Honda Accord 4 cyl Automatic 113000 miles
My grandpa said I should get the timing belt replaced every 100,000, is that true? There also seems to be a squeaking noise when the car is in reverse. And (only when the window is open do I hear it) there is squeaking that seems to be coming from the tires because the "tempo" or the squeak is directly related to the speed at which I am going. For example, just driving through the neighborhood and coming up to a stop sign, there's a kind of "wheel of fortune" type thing that happens, like the slower the tire spins, the more time there is between squeaks, if that makes sense. Is that something I should be concerned about?
Sep 21, 2009 at 11:43 AM
