Hi GRANDmotherocks,
Thank you for the reading material. We have something in common here, we both are workaholics. Though I am not a grandfather yet, maybe in a few years time, but I am no more that young, though to old to be your son.
Lets se what we can do about your questions.
MANUFACTURER'S SUGGESTED SCHEDULED MAINTENANCE
Normal replacement interval is at 105,000 miles or 84 months. Replace at 60,000 miles if vehicle is regularly driven in extreme temperatures (over 110 degrees F, or under -20 degrees F).
© 2008 Mitchell Repair Information Co., LLC.
Above are suggested timing belt replacement schedules so now is the correct time to get them done as the age of the belt is already long overdue.
1. There are quite a numbe of after market parts available at parts outlets and they should come much cheaper than from the dealer. Don't go for those extremely cheap ones as they would not last half as long as OEM. Apart from the timing belt, there is the balancer belts and tensioners. The valve cover gasket, bushes, plug seals, camshaft and crankshaft seals is recommended to be replaced at the same time as they should be worn as well.
2. If the guy knows what he is doing, then yes, you can go to him but he should give you a warranty on the job, unless he is not sure of what he id doing. If you are looking for references, go to major parts stores and ask around for recommendations. If more than two places recommends a certain mechaninc, he should be ok.
3. Book time for replacement of timing belt and water pump is listed at around 4 hours. Rates differs region to region so you should ask the mechanic his labor rates. I am not based in the US so I am not sure of prevailing rates and understand it ranges from $75 to $ 120 per hour depending on area.
4. It is good to understand the replaced parts condition and telling the mechanic that you want to have a look at the parts is ok. Get him to explain the condition and his opinion, that would make him feel that his opinion is valued.
5. The time for the work is ripe and your woman's intuition should be correct.
6. I always give my honest opinion to whoever I deal with and is always sad when I hear of people who gets ripped off by mechanics. Those who do it are the black sheep of the industry and that is one of the reaon for our site here, to help people understand how to go about and avoid being taken for a ride.
7. I know how it is to be struggling with a tight purse string. Not all mechanics are making tons of money, unless I am the exception.
8. You would be notified automatically when a post is made so no worries about that but sometimes the notification goes to the spam folder depending on your settings.
9. You're welcome. Hope what I have for you is helpful.
Have a nice day and let me know if you require anything further by replying to this post.
Jan 11, 2021 at 9:16 AM
(Merged)
