1999 Honda Accord Sunroof Malfunction
1999 HONDA ACCORD
100,000 MILES • 4 CYL • FWD • AUTOMATIC
CASA159
The sunroof on my car no longer tracks backward to open. It will crack open as intended, but when you hit the switch to recess the roof, it only moves about 1cm. Any ideas on what I can check to maybe resolve this issue, or is a trip to the dealer my only solution?
Jun 12, 2008 at 11:11 AM
  • 31,937 POSTS
Hi there,
If it starts to move and stops in the same position, the gear drive on the motor may be damaged. Can you still here the motor running? or is it cutting out? there may me an over lode switch shutting it down id the retraction mechanism is over tight.
Mark (mhpautos)
Jun 12, 2008 at 11:26 AM
