1999 Honda Accord Strut replacement
160,000 MILES • 4 CYL • FWD • AUTOMATIC
JSRACER
The struts were replaced on my 99 Accord a little less then a year ago. At that same time I had them do an alignment. About a month ago they started squeaking. They are covered under warranty until February so I took it in to the shop that did the original replacement. They said it was the strut mounts but they are replacing the entire strut and mount on both sides. I have to pay for the labor though and they said it needs an alignment at $70. Do I really need another alignment if I replace the struts?
Dec 15, 2009 at 9:40 AM
  • 31,937 POSTS
Hi there,
Yes you must have the alignment re adjusted as all the setting will be disturbed with the removal of the struts again.
mark (mhpautos)
Dec 15, 2009 at 7:20 PM
