When engine stalled, if the dash indicator lights do not come on, it means the ignition switch ON circuit is bad as power is not getting past the switch.
The security light coming on indicates the power has been interrupted.
When engine is running, check if the ignition switch is hot to the touch, indicating poor contacts internally. A good ignition switch would not emit too much heat.
Sunday, February 19th, 2017 AT 2:19 PM
