1999 Honda Accord speedometer tack
COOLGIRL
1999 Honda Accord 6 cyl
my speedometer tack has flipped all the way around and can't flipped back. It happened after I unhoocked the battery. what do i do with out spending lots of money.
Aug 6, 2010 at 7:17 AM
KHLOW2008
  • 41,812 POSTS
Hi coolgirl,
If you can get a fine stiff wire to turn the needle anticlockwise to the resting position, that should work.
Otherwise you need to remove the meter cluster to do it.
Aug 8, 2010 at 2:28 AM
