1999 Honda Accord spark plug tubes
162,000 MILES • 4 CYL • 2WD • AUTOMATIC
ALVIN78
spark plug removal has seized had to remove have already removed valve to get better access
Aug 11, 2008 at 12:10 PM
KHLOW2008
  • 41,812 POSTS
Hi alvin78,
It is not going to be easy when the plugs had not been removed for a long time.
1. You can either try to apply some rust remover and let it soak through before trying to remove.
2. Should have run the engine to make it hot before attempting to remove the plugs.
Aug 12, 2008 at 3:58 AM
