1999 Honda Accord SMOG CHECK REPORT
84,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVIES1
CAR PASSED EMISSIONS TEST, FUNCTIONAL TEST FAILED. NO CHECK ENGINE LIGHT PROBLEM. TECH SAID OBD2 CONNECTOR PROBLEM, NO COMMUNICATION.TOOK IT TO ANOTHER SHOP, ALL CODES WERE FINE, NO PROBLEM WITH OBD2. FAILED AT TEST ONLY CENTER, COULD THEIR EQUIPMENT BE WRONG?
Aug 30, 2010 at 4:17 PM
  • 75,988 POSTS
If the shop you went to can pull code/s and test center unable to -could be an operator's headspace or their Eq is malfunctioning or whatever the case maybe.
Aug 30, 2010 at 5:36 PM
