1999 Honda Accord RPM Jump when step on gas pedal but car d
1999 HONDA ACCORD
170,000 MILES • 6 CYL • 2WD • AUTOMATIC
HONDAFAN09
Hi!
Please help! I just changed EGR, Clean inside Manifold, changed sparkplug cable, Clean EGR Port, last few day it get hot here 97 degree, the car running fine for beginning then after 1 hour when I stop on the red light, and start moving the car I step on gas pedal and the RPM needle move to 2000 or 3000 RPM but the car doesn't not move until I hit on the gas pedal one or two times then the RPM start normal and the car could run fine. It is only happen when driving in local street low speed or 20-30 mph. It seem like the RPM idle does not stable and I don't know what wrong with please help any idea ? Use ODB 2 scan code come out 0740 relate to transmission lock up solenoid valve.. I don't know that cause the the problem?
Check engine light one but D4 light indicate does not come on. Thanks for your help
Jun 24, 2009 at 5:58 AM
KHLOW2008
  • 41,814 POSTS
Hi hondafan09,
P0740 is the lock up solenoid and is not related to the symptoms description.
I believe your problem is due to low fluid level or incorrect fluid used. Otherwise the trans is failing.
Jun 27, 2009 at 10:18 PM
