HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Accord
Steering
Pump
Replace/Remove
1999 Honda Accord power steering pump replacement
LUCKYDOG1
MEMBER
1999 HONDA ACCORD
4 CYL
FWD
AUTOMATIC
130,000 MILES
Is there anything special I need to know b4 attempting to replace my steering pump, such as the pulley removal and fluid?
Saturday, October 30th, 2010 AT 6:49 PM
CJ MEDEVAC
MECHANIC
See my profile,
This is a very good resource, almost a secret!
Few go here to see whats available
This may assist you in knowing what's involved
https://www.2carpros.com/topics/miscellaneous/power-steering-puller
http://www.youtube.com/watch?v=5WPLowC6aZo&feature=related
Let me know if this helped, below at "reply to question"
Your Turn
The Medic
Saturday, October 30th, 2010 AT 7:13 PM
Please
login
or
register
to post a reply.
Related Steering Pump Replace/Remove Content
Power Steering Pump Noise After Timing Belt Change
1998 Honda Accord V6 128,000 Miles I Took It In To Have The Timing Belt Changed. When I Picked Up The Car After The Timing Belt Change...
Asked by
dobryan2000
HONDA ACCORD
VIDEO
Power Steering Pump Replacement
Instructional repair video
GUIDE
A power steering pump is driven by the engine and is designed to supply pressure via the steering fluid to the steering box or rack and pinion. This pressure is transferred...
1990 Honda Accord Removal Of Power Steering Pump
Hi, I've Been Trying To Remove The Power Steering Pump And I Was Able To Remove Two Bolts, One On The Top, And Another One That Looks...
Asked by
chevy106
1 ANSWER
1990
HONDA ACCORD
Power Steering Pump Whine?
I Have Replaced The Power Steering Pump On My 98 Honda Accord V6 And Its Still Making Noise
Asked by
haw310
1998
HONDA ACCORD
Steering Pump
I Change The The Steering Pump Ona 2000 V6 Accord. Because The Old Pump Bearing Went Bad And Bleed Out The Pump And Use Honda Oil And Still...
Asked by
rockyroster
2000
HONDA ACCORD
1992 Honda Accord Power Steering Pump
Steering Problem 1992 Honda Accord 4 Cyl Two Wheel Drive Automatic Since My Garage Replaced A Leaky Pipe From The Steering Pump To...
Asked by
estiy
1992
HONDA ACCORD
VIEW MORE
Steering Pump Replacement Mercedes Benz
How to Replace a Power Steering Pump
