1999 Honda Accord P1457 Check Engine Light Code
113,000 MILES • 4 CYL • 2WD • AUTOMATIC
JANKARNALA
My car had engine light turned on, I got error code P1457. I tried by replacing my fuel cap. But problem still exists. May be some option as below
Vapor canister saturated
Failed vent solenoid
Failed purge solenoid
Can you tell me how much cost each failure. concidure most common parts
Mar 3, 2009 at 6:37 AM
  • 75,988 POSTS
The options you got could be one of it-The best method is run a smoke test machine on it-
Mar 3, 2009 at 6:43 AM
