car will not pass n.j. state inspection. code p-1491 egr low passage code keeps coming up. I replaced the egr ( after market) , tried cleaning the 2 ports under the egr valve by spraying brake cleaner and pushing bailing wire to clear any obstrution but the bailing wire would only go so far. Need to know is there another synsor to be replaced or how to fix the problem to pass inspection. THANK YOU
Jun 17, 2008 at 12:13 AM
