1999 Honda Accord Oil Leak and Engine Surging
LBLUNDELL
Engine Performance problem
1999 Honda Accord 6 cyl Automatic 120000 miles
I just purchased a 1999 Honda Accord EX from a dealership. Less than a week later, I noticed a leak. It is located towards the front, on the right hand side not far from center. I brought it back to the dealer and they replaced the oil drain plug bolt but it is still leaking. It seems to leak after I have driven it and then stops after several hours of being parked. I also noticed a surging of the engine when parked. the rpm kept going up and back down, quickly. when I pressed the gas, it ended up stopping. Do you have any ideas as to what might be wrong?
Jun 19, 2008 at 10:19 AM
ITSALLGOOD
  • 37 POSTS
There a few things that wil make the engine surge like that.
The first thing I would look for is a vacuum leak. Replace the PCV valve first, and make sure that the hose that is attached to it is not brittle or broken.
Jun 19, 2008 at 3:04 PM
KHLOW2008
  • 41,812 POSTS
Hi lblundell,
If it is the drain plug, it will continue to leak no matter how long you park, the longer, the more oil will leak out.
I suspect it is an oil seal, most probably flywheel oil seal.
Jun 20, 2008 at 1:53 AM
