I don't have any rear running lights
170,000 MILES • 6 CYL • 2WD • AUTOMATIC
99BAGGEDACCORD
I don't have any rear running lights. Front running lights work . I checked all fuses in all 3 fuse box locations and all are ok .. brake lights work when I press on them . Please help anything else I can check . All gronds and wires seem to be ok just don't know if there are any modules or relays to check ..thanks
Apr 4, 2010 at 4:06 PM
KHLOW2008
  • 41,812 POSTS
Did you check the bulbs? The taillight and brakes are 2 different circuit and the taillight bulbs can fail with the brake lights in good working condition.
The front and rear running lights are in the same circuit so it should not be a fault with the fuses. If the bulbs are good, then the most likely cause would be a loose connector somewhere.
If you have a test lamp, test the taillight Red/Black wire for battery voltage with the lights turned on.
May 17, 2021 at 5:29 AM
99BAGGEDACCORD
i tested the red and black wire for voltage and nothing and all fuses are good is there a relay or module i can check .. i had this issue with the fronts awhile back and my car audio buddy hooked up a jumper wire with fuse and relay .. we checked what he did and that is still ok .. so i am guessing a relay or something else
KHLOW2008
  • 41,812 POSTS
As the front lights are working, it is not a fuse or relay issue.There is an open in the wire and it could be from the under dash fusebox.Use the test lamp to test the Red/Black wire at under dash fuse box connector to the rear, at driver kick panel.
