Did you check the bulbs? The taillight and brakes are 2 different circuit and the taillight bulbs can fail with the brake lights in good working condition.
The front and rear running lights are in the same circuit so it should not be a fault with the fuses. If the bulbs are good, then the most likely cause would be a loose connector somewhere.
If you have a test lamp, test the taillight Red/Black wire for battery voltage with the lights turned on.
SPONSORED LINKS
Monday, May 17th, 2021 AT 12:29 PM
