1999 Honda Accord ignition barrel
1999 HONDA ACCORD
79,000 MILES • 4 CYL • 2WD • MANUAL
PURPLENICK
can ignition barrel be replaced without steering lock unit?will it need programming if replaced with new barrel and key?thankyou
Jul 21, 2009 at 4:27 AM
KHLOW2008
  • 41,814 POSTS
Hi purplenick,
For manual transmissions the key cylinder can be replaced separately.
If vehicle is equipped with immobilizer system, the key would need to be reprogrammed. To avoid reprogramming the key, you can rebuild the new key cylinder to match the old key.
If not equipped with immobilizer, no programming is required.
Jul 26, 2009 at 7:45 AM
