1999 Honda Accord Idle
KENNY1999
Engine Mechanical problem
1999 Honda Accord 4 cyl Two Wheel Drive Manual
The car idles fast between 1000 and 1500 rpms. blue smoke when first started. .
Apr 19, 2010 at 3:06 AM
KHLOW2008
  • 41,812 POSTS
Hi Kenny1999,
When engine idles higher than 800, there could be a vacumn leakages, shortage of coolant, clogged coolant hoses to the Idle Air Control Valve, stuck IAC or idle speed is out of adjustment.
Blue smoke during initial start up indicates oil is being burnt in the cylinders and the most common fault is worn valve seals.
Apr 20, 2010 at 5:38 AM
