1999 Honda Accord Hot air from the blower at startup
1999 HONDA ACCORD
99,500 MILES • 4 CYL • 2WD • AUTOMATIC
SANDIRAS
I have 1999 Honda Accord and recently had to fix the Evap two valve assembly beacuse of vapours leaking. After a month, I have this problem, when engine starts up and running for sometime it blows hot air from the A/C blower, although outside temperature is cool. Once I turn the A/C on and have the car running for sometime then the compressor make it cool and I switch the A/C off.
After that, I wil not get hot air as long as the car is running.
Why is this problem coming at startup? Is it related to replacing the Evap 2-valve assembly?
Thanks!
Apr 10, 2009 at 8:27 AM
KHLOW2008
  • 41,814 POSTS
Hi sandiras,
Nothing to do with the EVAP but while doing replacement, you could have dislodged the heater control valve linkages or vacumns.
Check that out.
Apr 15, 2009 at 5:59 AM
