1999 Honda Accord HELP WITH A/C
160,000 MILES • 4 CYL • FWD • AUTOMATIC
ALFSOL147
My a/c control panel has no power when turning on the a/c switch or the recirculation switch. This problem began as an intermittent problem, but now is a solid no power problem. The blower switch works.
I have checked the fuses and all are ok. Is there a relay that controls power to the switch panel?
thanks.
Jul 14, 2010 at 5:19 AM
KHLOW2008
  • 41,812 POSTS
Hi alfsol147,
The panel receives its power straight from the fuse box without any relays in between.
The control panel is known to fail quite often and symptoms indicates so. The printed circuit board is the main culprit.
Jul 17, 2010 at 10:49 AM
