1999 Honda Accord LX 4 cylinder
Mileage $43,000 (yes that is correct, very little driving) / Automatic/ 2 wheel drive/4 dr sedan
Only repairs: battery/tires,. Recently making grinding noise, like metal on metal only when car is moving. Doesn't matter what speed, noise stops when press on brake pedal. Sound coming from front passenger side. Noise does not happen all the time, sometimes once a day or less, but only when car is moving & it stops when brakes applied. Sometimes starts back up again minutes later, sometimes not. Had tires rotated today, they said brakes looked OK, but they are not certified for brakes, tire only shop. Friends suggest: Ball Joints/Wheel Bearing/CV joint or boot/ Axle bearing/drive axle/Brake pads &/or rotors. Hope to diagnose w/o having to fix or check all above problems. Please advise & thanks much
Jul 21, 2007 at 8:45 PM
