Hi sixisuper,
Thank you for the donation.
There are 2 items that cn cause such intermittent problems.
1. Ignition switch. A safety recall was issued for this component and the symptoms are as described. When problem occurs, check if the ignition switch is heated up at the base.
2. PGM-FI main relay. This component is known to fail intermittently causing stalling while driving. When engine could not be started, check if the fuel pump is working.
SPONSORED LINKS
Sunday, February 19th, 2017 AT 2:28 PM
